Linkwitz Lab !
Linkwitz Lab !
Vi segnalo un link sperando che sia interessante
Scusate ma io non sono in grado di capirlo
http://www.linkwitzlab.com/design_of_loudspeakers.htm
Re: Linkwitz Lab !
Interessantissima osservazione, questa. Domani approfondiamo (con tanto di traduzione).
S.linkwitz ha scritto:H - Psycho-acoustic 3 kHz dip
Our perception of loudness is slightly different for sounds arriving frontally versus sounds arriving from random directions at our ears. The difference between equal-loudness-level contours in frontal free-fields and diffuse sound fields is documented, for example, in ISO Recommendation 454 and in E. Zwicker, H. Fastl, Psycho-acoustics, p. 205.
Diffuse field equalization of dummy-head recordings is discussed in J. Blauert, Spatial Hearing, pp. 363, and headphone diffuse field equalization by G. Theile in JAES, Vol. 34, No. 12.
Reference to a slight dip in the 1 to 3 kHz region for loudspeaker equalization is made in H. D. Harwood (BBC Research Department), Some factors in loudspeaker quality, Wireless World, May 1976, p.48.
Around 3 kHz our hearing is less sensitive to diffuse fields. Recording microphones, though, are usually flat in frequency response even under diffuse field conditions. When such recordings are played back over loudspeakers, there is more energy in the 3 kHz region than we would have perceived if present at the recording venue and a degree of unnaturalness is introduced.
This applies primarily to recordings of large orchestral pieces in concert halls where the microphones are much closer to the instruments than any listener. At most listening positions in the hall the sound field has strong diffuse components.
I use a dip of 4 dB (x1.gif, 2760NF) to equalize for this. The circuit consists of R, C and L in series, forming a frequency dependent ladder attenuator in conjunction with the 5.11k ohm source resistor. You may choose to make the notch filter selectable with a switch for different types of recordings.
I have found through my own head-related recordings of symphonic music that the dip adds greater realism, especially to large chorus and to soprano voice and allows for higher playback levels.
Re: Linkwitz Lab !
Bello questo argomento
Nei tuoi diffusori Fabrizio tendi ad applicare questa attenuazione intorno ai 3000 Hz oppure lasci la risposta lineare?
Ma poi, mi chiedo, (l'attenuazione) non è che magari conviene applicarla nella regione di incrocio del diffusore?
Re: Linkwitz Lab !
...e giacchè ci siete, se non vi fa inorridire la sospensione pneumatica, andatevi a leggere il progetto di Thor, il subwoofer con lo "small pin hole (<1 mm diameter)".Giu-no ha scritto: ↑venerdì 30 settembre 2016, 18:30Vi segnalo un link sperando che sia interessante
Ciao!
P.S. Lo so che "questo non è un forum per auto-costruttori" ma mi ha incuriosito quel "forellino", adoperato anche dalla B&W https://www.digitalvideoht.it/prove/aud ... -db2d.html
Ultima modifica di Teo Marini il lunedì 30 novembre 2020, 9:39, modificato 1 volta in totale.
Re: Linkwitz Lab !
Qualche volta l'ho fatto, ed effettivamente la cosa è risultata piacevole.bobgraw ha scritto: ↑domenica 29 novembre 2020, 22:30Bello questo argomento
Su altri impianti (p.es. il Poliedro) è risultata inutile.
Sull'impianto per la cordata è un possibile optional (da memorizzare sul DCX) da provare ad ascoltare: non costa nulla.
Re: Linkwitz Lab !
È ... alla BeW li sanno fare i buchetti, mica io, che se mi capita la cassa soffia come una vipera
Re: Linkwitz Lab !
Boh!?Toscanaccio ha scritto: ↑lunedì 30 novembre 2020, 18:21È ... alla BeW li sanno fare i buchetti, mica io, che se mi capita la cassa soffia come una vipera
Re: Linkwitz Lab !
Il riferimento era al subwoofer tor e al suo "Small Pin hale" ma può darsi che non ci abbia capito nulla, nel qual caso chiedo scusa
Re: Linkwitz Lab !
Ma no, non c'è di che scusarsi...Toscanaccio ha scritto: ↑martedì 1 dicembre 2020, 20:23Il riferimento era al subwoofer tor e al suo "Small Pin hale" ma può darsi che non ci abbia capito nulla, nel qual caso chiedo scusa
Il motivo del mio OT nasce dal fatto che anch'io ho sempre saputo che le piccole fessurazioni nelle s.p. possono provocare sibili e sono rimasto perplesso nel leggere della soluzione adottata da Linkwitz (che non era certamente un fesso...).
Per questo chiedevo pareri...
E tu, il tuo l'hai dato...
Ciao!
