http://www.longdogaudio.com/project/lda ... mplifiers/
The p6 is no different. Conventional power amplifiers use multiple arrays of output devices paralled up to achieve the output power. A typical device might have a maximum power rating of 150W, and a maximum current of 20A. So using those to give you a 200W amplifier, you have to consider using four pairs. Now, its been our experience that paralleling any active device while attractive from a specification aspect, always seems to have a sonic cost when the result is used to play music. The solution to this problem, of getting high power without multiple output devices is now available thanks to the semiconductor industry. The requirement for high power devices for the power transmission industry had lead a number of manufactures to produce very high power parts. For example, a single device that can handle 100A, with a maximum power on the right side of 900W. Suddenly those parallel devices don’t seem required. In the past high power devices have been available, but internally they are actually just multiple lower power devices in parallel, so no real advantage to us. But now there are true single die high power mosfets available, and even better, they are available in complementary pairs so we can make a truly balanced amplifier, and better yet, they are specified for linear use, so we are not going to have any unexpected failures along the line. What more could we (as designers) want?
Well, in truth, there are always downsides, its not all good news. As well as having these great power handling numbers, they also come with a problem, they are hard to drive. So the problem now switches to the stage before the output stage. But again, there is a answer. Use a smaller power amplifier to drive them. So that’s just what we do in the p6. Each one of the pair of output devices for each monoblock, is itself driven by a smaller push pull amplifier constructed (of course) by using a single pair of smaller output devices. Each half of the output stage is itself driven by a push pull amplifier. So its “Push (Driven by Push, Pull), Pull (Driven by Push, Pull)”. So thats six P’s, thats why this amplifier is called the p6.
Il p6 non è diverso.Gli amplificatori di potenza convenzionali utilizzano più array di dispositivi di output in parallelo per raggiungere la potenza di uscita.Un tipico dispositivo potrebbe avere una potenza massima di 150W e una corrente massima di Quindi, usando quelli per darti un amplificatore da 200W, devi considerare l'utilizzo di quattro coppie: ora è stata la nostra esperienza che parallelizzare qualsiasi dispositivo attivo mentre è attraente da un aspetto specifico, sembra sempre avere un costo sonico quando si utilizza il risultato per riprodurre la musica La soluzione a questo problema, di ottenere alta potenza senza più dispositivi di uscita, è ora disponibile grazie all'industria dei semiconduttori Il requisito per dispositivi ad alta potenza per la trasmissione di potenza l'industria aveva portato un certo numero di produttori a produrre parti molto potenti. Ad esempio, un singolo dispositivo in grado di gestire 100 A, con una potenza massima sul lato destro di 900W. Improvvisamente quei dispositivi paralleli non sembrano necessari. In passato i dispositivi ad alta potenza sono stati disponibili, ma internamente sono in realtà solo più dispositivi di potenza inferiore in parallelo, quindi non ci avvantaggiano. Ma ora ci sono veri mosfet single-die ad alta potenza disponibili, e ancora meglio, sono disponibili in coppie complementari in modo che possiamo creare un amplificatore veramente bilanciato, e meglio ancora, sono specificati per l'uso lineare, quindi non avremo alcun fallimenti imprevisti lungo la linea. Che altro possiamo (come designer) vogliamo?
Beh, in verità, ci sono sempre aspetti negativi, non tutte le buone notizie. Oltre ad avere questi grandi numeri di gestione della potenza, hanno anche un problema, sono difficili da guidare. Quindi il problema ora passa allo stadio precedente allo stadio di uscita. Ma di nuovo, c'è una risposta. Utilizzare un amplificatore di potenza più piccolo per guidarli. Quindi è proprio quello che facciamo in p6. Ciascuna delle coppie di dispositivi di uscita per ciascun monoblocco è a sua volta pilotata da un amplificatore push-pull più piccolo, costruito (ovviamente) utilizzando una singola coppia di dispositivi di uscita più piccoli. Ogni metà dello stadio di uscita è a sua volta pilotata da un amplificatore push-pull. Quindi la sua "spinta (spinta da spinta, trazione), spinta (spinta da spinta, trazione)". Quindi questo è sei P, ecco perché questo amplificatore è chiamato p6.
Re: Ad esempio, un singolo dispositivo in grado di gestire 100 A
Ho qui nel cassetto alcuni SPW47N60C3. Sono dei mosfet recuperati da tv al plasma, quindi anche un po' datati. Sono dati per 600 V, 47 A, 415 W. Confrontandoli con uno di quelli più usati da Pass, IRFP240, 200 V, 20 A, 150 W, e andando a vedere le capacità delle giunzioni, ma soprattutto la gate charge, quest' ultimo sembra più facilmente pilotabile, anche mettendone 3 in parallelo. La transconduttanza invece è molto minore.
Chissà come suonano ? Ooops! Non c'è il complementare ! Beh, ma questo non scoraggia gli autocostruttori/sperimentatori più irriducibili
vai di simmetria quasi complementare o se fai il dannato di trasfo in stile mac
