Quando il pro mi piace :-)
Moderatore: Marcello Croce
elettro
Re: Quando il pro mi piace :-)
#11 Messaggio da elettro » venerdì 20 maggio 2022, 1:14
Eh...interessante..soprattutto la via alta..
#12 Messaggio da bobgraw » venerdì 20 maggio 2022, 12:14
VO1D ha scritto: ↑
sabato 6 novembre 2010, 0:41
Air motion si chiamano, ecco altre foto
Zoom http://farm4.static.flickr.com/3259/308 ... 1b1d_b.jpg
Praticamente le casse che vorrei avere in casa!
Riccardo
Bellissime, hanno tutta l'aria di essere performanti, il disegno del gruppo medio alti mi ricorda i cardini delle trombe utilizzate da Fabrizio..
#13 Messaggio da bobgraw » venerdì 20 maggio 2022, 12:50
E questi satelliti VOID AIR 8 quanto sono belli??
Void-Air-8 (Copy).jpg (9.25 KiB) Visto 28853 volte
The loudspeaker shall be a passive two-way system
consisting of one high power 8” (203.2 mm) direct
radiating reflex loaded low frequency (LF) transducer
and a 1” (25 mm) diameter co-axially-mounted
neodymium high frequency (HF) compression
transducer mounted in a fibreglass, smooth cellulose
enclosure.
The low frequency transducer shall be constructed
on a cast aluminium frame, with a treated paper cone,
50.8 mm (2”) voice coil, wound with copper wires
on a high quality voice coil former, for high power
handling and long-term reliability. The high frequency
transducer shall be bolted through the rear of the
magnet structure belonging to the LF transducer
to form a co-axial drive unit. The sound will project
through a machined waveguide that exits in the centre
of the low frequency transducer to use the 203.2 mm
(8”) baffle diameter to achieve pattern control and low
distortion.
Performance specifications for typical production
unit shall be as follows: the usable on-axis bandwidth
shall be 70 Hz to 20 kHz (±3 dB) and shall average
90° directivity pattern for both horizontal and vertical
axis (-6 dB down from on-axis level) from 1 kHz to 10
kHz; maximum SPL of 119 dB continuous, 121 dB peak
measured at 1 m using IEC268-5 pink noise. Power
handling shall be 300 W AES at a rated impedance of 8
Ω; crossover point at 2 kHz using a 4th order filter (24
dB per octave).
The wiring connection shall be via a single, removable,
lockable wiring connector with four screw-down
terminals (one pair for input and one pair for loop-out
to another loudspeaker) to provide secure wiring and
to allow for pre-wiring of the connector before the
installation. This connector should then screw lock to
the enclosure to ensure secure attachment.
The enclosure shall be of a moulded fibreglass
reinforced plastic construction with a smooth cellulose
finish and shall include integral threaded inserts for the
fitment of wall and ceiling mounting hardware of any
RAL colour with external dimensions of (H) 420 mm x
(W) 299 mm x (D) 171 mm (16.5” x 11.8” x 6.7”). Weight
shall be 6.2 kg (13.7 lbs).
https://voidacoustics.com/product-range ... ries/air-8
elettro
#14 Messaggio da elettro » sabato 21 maggio 2022, 19:21
Ste void non le ho mai ascoltate ...peccato...
elettro
#15 Messaggio da elettro » domenica 12 giugno 2022, 15:59
Quelle trombe potrebbero anche suonare se....
