Per celebrare degnamente i 75 anni dalla fondazione, la JBL ha rilasciato...
oblomov
Messaggio da oblomov » venerdì 16 aprile 2021, 21:42
100 Classic In 1970, JBL released the iconic L100 Loudspeaker. Over the years, the L100 became the bestselling loudspeaker in JBL’s history. In 2018, we are proud to bring you the JBL L100 Classic, a modern take on a time-honored legend. The Classic features vintage styling, including a retro-inspired design and iconic Quadrex foam grille, along with newly developed acoustic technology and designs for elite performance. The 1-inch titanium dome tweeter is mated to a waveguide with an acoustic lens for optimum integration with the 5-inch pure-pulp cone midrange driver directly below it. Powerful bass is provided by a 12-inch cast-frame, white pure-pulp cone woofer in a bass-reflex enclosure, tuned via a single front-firing port tube. The high-frequency and mid-frequency L-pad attenuators on the front baffle preserve the classic features of this iconic legend. General Specifications Low-frequency transducer 12-inch (300mm) pure pulp cone woofer (JW300PW-8) mid-frequency transducer 5.25-inch (125mm) polymer-coated pure pulp cone (105H-1) High-frequency transducer 1-inch (25mm) titanium dome with soft surround (JT025TI1-4) Sensitivity 90dB (2.83V/1m) Power Handling 25 - 200 Watts RMS Crossover Frequencies 450Hz, 3.5kHz Audio Specifications Impedance 4 Ohms Frequency Response 40Hz – 40kHz (-6dB) Dimensions Dimensions 25.06 x 15.34 x 14.625 inches (636.52 x 389.64 x 371.48mm) Weight 58.5 lbs (26.7 kg)
Il leggendario JBL L100 del 1970 si rinnova. Iconico stile JBL che ripropone la griglia in schiuma dal design retrò/vintage Quadrex, disponibile in nero o arancio. Diffusore da libreria/stand con woofer da 12" di colore bianco e cestello in pressofusione. Midrange con cono da 5". Tweeter a cupola in titanio da 1". Attenuatore per medie e alte frequenze. Crossover: 450Hz, 3.5kHz. Potenza di amplificazione massima raccomandata 25-200 W (RMS); risposta in frequenza 40Hz-40kHz (-6dB); impedenza 4 Ohm; sensibilità (2.83V@1m) 93 dB SPL. Terminali dei diffusori binding-post. Dimensioni (LxAxP): 636,52 x 389,64 x 371,48 mm. Peso 26.7 kg. Finitura cabinet: NOCE. Colore griglia frontale: Arancio o o nero -Optional stand js 120 250,00 euro cadauno
Per celebrare degnamente i 75 anni dalla fondazione, la JBL ha deciso di rilasciare un'edizione limitata del suo best-seller progettato esattamente 51 anni fa, ovvero il diffusore L-100 Classic. Si chiamano L100 Classic 75 e saranno disponibli da aprile in 750 coppie numerate e selezionate/accoppiate accuratamente (matched pairs, come si dice).Le caratteristiche sono quelle usuali della L100 classica, con un cabinet in legno di teak e una griglia parapolvere a quadrettoni che ricorda esattamente quella di 50 anni fa. Piccole modifiche tecniche riguardano un nuovo profilo per la sospensione del woofer e un nuovo crossover, ora predisposto per il biwiring. Inclusa nel prezzo anche l'immancabile coppia di stand dedicati denominati JS-120. Per acquistare tutto il pacchetto, dovete mettere da parte circa 5500 dollari.
Re: Per celebrare degnamente i 75 anni dalla fondazione, la JBL ha rilasciato...
Messaggio da bobgraw » venerdì 16 aprile 2021, 23:32
Come già per le Magnat Transpuls, le Wharfedale Linton e altre recenti casse di taglia media, l'unico segnale positivo che vedo, è forse la fine della moda dei mini-diffusori (e conseguente mini-suono) da stand e da pavimento.
Per il resto ad occhio considerando che sono passati cinquant'anni, mi sembra che le L100 by Synthesis siano peggiorative, perlomeno nel woofer col gommone e un mid che, già che ormai ne abbiamo imparato l'importanza, avrebbero potuto far crescere almeno leggermente.
AltaEfficienza
Messaggio da AltaEfficienza » sabato 24 aprile 2021, 14:28
Fascino intramontable le JBL ...
Come dire "i McIntosh" dei diffusori ;)
Messaggio da F.Calabrese » sabato 24 aprile 2021, 14:48
Non offendiamo la JBL, perlomeno quella vera, di un tempo...!!! ;) ------- :lol: ------- ;) ------- :lol: ------- ;)
elettro
Messaggio da elettro » venerdì 30 aprile 2021, 2:00
Perlomeno, hanno i piedistalli inclinati...in giro di vede di molto peggio...
